HAL.VLAN.AllocCndtMsgFail
Description
Conduit module used up the pre-allocated messages in a pool.
Remedy
Increase the log severity of HAL.conduit to collect more data. If all the conduit messages in the pool are used, this error occurs. Check if Conduit raised an error. If an IOB is hot swapped but HAL has not detected the change, the error also can happen. Check if IOB is in the slot and operational.
Severity
Debug-Data
Message Text
Failed to allocate a conduit message %mesgType% for port %slot%:%port% VLAN ID %vlanId%.
Message Parameters
Name Type
slot Slot
port Port
vlanId VLAN-tag
mesgType uInt32
Applicable Platforms
